RCU Forums - View Single Post - Cold Duck - Build
Old 07-09-2006 | 06:35 PM
  #211
aerowoof
Default RE: Cold Duck - Build
8178,
forgot to ask, when you made the fuselage 1/2 narrower did you just modify f-2 and f-3 or did you take 1/2 off from the firewall thru f-4?thanks.also when you increased the span of the stab i am assuming that the tip and root chord remained the same?
by the way i will be using and updated Kraft 7Z tx and rx but futaba 130 servos and a 136g on the retracts.
