RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 07-09-2006 | 09:02 PM
  #4852
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
xxsnookxx... I use a APC 12.25X3.75 on my OS 46... For me it's a good prop. Your
evo should spin it good also... APC's are a bit heavy, But they are about the best prop
that you can get for the $$$$.. I've used Pro Zingers mostly 14X4W.. But they are a bit
inefficient...The other wood props are a lot better at pushing air... Your 46 will fly the "Do"
But to do all that the "Do" will do you will want a bit more power... Most including myself
use the Saito 82, I also had a YS 63 and a Saito 100 on the "Do"... I tried the S-100 after
a "power demon" loved it on his "Do"... The "Do" handles the 100 good..... You do have
to control that left stick... This plane does not like a lot of speed...
Your ail. should be OK depending how far they are off.. Sometimes laying the ail. on a
level flat table etc. and holding it flat against the table and heating the covering with an
iron/ heat gun will help to strighten it.. Or have someone lightly twist the high part of your
ail and again heating it, holding it till it cools will help strighten it.. The control rods are a
bit light for this plane, I used 4/40 rods, a few went with the carbon fiber... And sounds
like you came up with another idea...
