ORIGINAL: TimC
boxbeam or Cambo, I'm curious what the manual says about break-in. I suppose it's different than the normal four stroke. I tried to download the manual but my Adobe is acting up.
The manual finally downloaded and I don't know if I agree with the instructions or not. "At full throttle, peak the engine for 5 seconds then richen 1 full turn of the high speed needle......."
This would result in a very rich condition which goes against the accepted method for breaking in an ABN engine. I'd like to hear what other members here think.
As has been pointed out, this is an ABN engine, which usually doesn't have that much pinch at TDC, such as with an ABC engine. I doubt that doing as they advise would be as damaging to this engine as it would be in a high ratio tapered engine such as a tight ABC engine.
Conversely, while I suspect that their way might break the engine in a little sooner, I can't see where it would hurt to treat the engine as though it were a pure ABC engine and not quench it with lots of fuel by running ultra rich. It "might" just take a little longer to settle in.
It's just my opinion, but I suspect that OS has chosen to fulfill the needs of the instant gratification crowd, while disregarding those that love engines that will last twenty to thirty years without a major rebuild. Giving someone an engine that is quickly ready to hover can be a serious advantage in today's marketplace.
I doubt that the folks at OS do not know what they are doing. Even the latest crowd. <G>
