Hurricane DB Models
Hi,
Good luck with your model, I am just about to start a DB Hurricane as well.
I have just finished the DB Spitfire which needed a ton of weight added up the front so I will be going out of my way to make sure the back end of the Hurri is as light as possible. How much weight did you have to add to the front of your Spitfires?
I plan to use a ST3250 2 stroke in the Hurricane, would love a 4-stroke but I would be worried that the Laser 180 would have trouble getting it off our short grass strip. I have a laser 120 in a Brian Taylor 109 which only spans about 70", it's enough but not by any means over powered.
Simon.
