RCU Forums - View Single Post - Engine tuneup
Old 07-10-2006 | 07:16 AM
RCLT40
Default RE: Engine tuneup
If you guys must have seen the spacing between the firewall and the engine on a H9 Twist. There isn't much room there so a bend might be the issue. Also because I'm using a fule dot I need to clamp of the line runing from the Tee to the cab on my 46 so when I fule it up it won't flud the carb. So, there the possiblity I may have a hole in it from doing that.
