RCU Forums - View Single Post - Engine tuneup
Old 07-10-2006 | 07:43 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Engine tuneup
ORIGINAL: RCLT40
Also because I'm using a fule dot I need to clamp of the line runing from the Tee to the cab on my 46 so when I fule it up it won't flud the carb.
Normally when a fuel dot is used a 3-line setup will be used on the fuel tank. This way you won't have to block the line to the carb. One line is your normal pickup line going to the carb, the second line is your vent line from the muffler, and the third line is used as your fill line. Make sure you put a clunk on the fill line so that you can drain the fuel tank too.
Hope this helps
Ken
