Question for Demon
Low-temp covering goes on just like regular covering. If anything, the low-temp stuff shrinks more and is generally easier to work with.
Be sure to spray on a light coat of spray adhesive and let it dry for at least 1 hour before covering, and use a low-temp iron.
As with covering any solid surface, start in the middle and work toward the edges. Other than that, just follow the covering manufacturer's instructions.
D
