RE: Profile P-38 on FLOATS- HELP
Jim
"Normally with one engine and two floats you'd only need spray rails on the insides of the floats. Your (2)floats are aligned with the (2)motors so you'll want to use rails on both sides of the floats. "
You expect NORMAL from someone who proudly calls himself "twinman"? Thanks for the information. The extension I built worked, but was much more difficult than your solution.
Twinman
PS Any advice not for the Gater??..no guns...County Park!!!
