RCU Forums - View Single Post - Engine tuneup
Old 07-11-2006 | 05:20 AM
Mr67Stang's Avatar
Mr67Stang
Default RE: Engine tuneup
ORIGINAL: RCLT40
I just had to check tonight before heading to bed. I pulled the tank and there is a spot for adding a third line. Just need to get the tube to put in there. I notice on you example that there is a secion of metal tubing about half way to the clunk. I would guess that this is what keeps it from swinging forward. Also, It seems that the fule dot line also connects to the clunk. Does it really need to have another clunk. Or one that can do two lines? I was hoping that I could just bend the pipe in an upward pattern like the pressure line.
Kris
The 2nd clunk is to hold that fill line at the bottom of your tank so it is easier to defuel at the end of the day.
