RCU Forums - View Single Post - PRIMUS Build
Thread: PRIMUS Build
Old 07-11-2006 | 12:24 PM
  #48
Skip's Avatar
Skip
My Feedback: (76)
Default RE: PRIMUS Build
Here I have drilled and glued the wing dowel in place and drilled and tapped the 1/4 -20 nylon wing hold down bolts. I installed the wing and it seats OK. I will make any minute adjustments if necessary to insure 0 degree incidence with the fuse. I set the stab in place just to see how it fits and it looks like it will take a little sanding to make it parallel to the wing. The stab looks huge in the picture due to the camera angle. After I do some internal bracing of the fuse ( firewall) I will add the top piece and sand to shape.
