RCU Forums - View Single Post - E-85 and model engines
Old 12-31-2002 | 10:49 AM
Ross Kean's Avatar
Ross Kean
Default E-85
I had to look that one up!
E-85 is a mixture of 85% ethyl alcohol (ethanol) and 15% gasoline. Sounds interesting. It would have a lot more energy per unit volume than standard glow fuel (but less than gasoline). This would translate into either more power or a longer run time per tankfull. I would worry about running too hot. There would be a lot less evaporative cooling than with methanol, plus the extra combustion energy. I think you would need to make sure there was really good air flow around the head.
Post your results, especially with respect to glow engines. Could be a good alternative to spark ignition engines. There might be some more choices with respect to oils as well. Is the mixture miscible with mineral oils or more conventional (automotive) synthetics?
Ross
