RCU Forums - View Single Post - piston ring
Thread: piston ring
Old 07-11-2006 | 03:01 PM
maayan
Default RE: piston ring
thanks!
* i would like to mention that the engine has great compression.
keeps steady idle. and turns good rpm.
and if i may, i have another question:
a couple of months ago i posted about my 91FSII-P.
the problem was that even with the needle fully closed- the engine still turns.
as i was advised i replaced the carb body with a new one, but still the same problem.
* the needle itself was also replaced.
i must say the engine does work smoother..
is it normal for a pumped engine?
thanks again
