RCU Forums - View Single Post - EVO 26 cc engines: opinions
Old 07-11-2006 | 03:39 PM
rmh's Avatar
rmh
Default RE: EVO 26 cc engines: opinions
None -use as is just use 18x6 prop of narrow blade design - do not invent new oil arrangements
this is an engine which -if you will do just as recommended -works extremely well - if you attempt large prop combos and lean oil setups -you will get negative results.
