Pump for OS 1.60FX?
Tony,
As long as your muffler gives you enough pressure to your fuel tank, you won't need a pump. A pump would be needed if you want to place your fuel tank away from the engine and close to the CG of the model. The long fuel lines will require that the fuel gets more "push" than muffler pressure will provide.
Any of the pump systems for the larger engines will work out well.
