The only time that the magneto's are checked is when you are on the ground, why be worried if the failure is on the ground?
Why? Because worn ignition switch's are known to start on the ground, then completly fail in the air, or on the ground when someone it turning the prop, thats why! Once it starts to hang up, its only a matter of time till it fails completly.
