Hi Kid,
My comments were not dislikes. They were just points in favor of gas engines. I can make a list just as long in favor of glow engines. I like them all. I havn't tried GGL yet, the posted results indicate that it is the best solution for small gas engines. Larger gas engines have a good power to weight ratio, where the inverse is true when you get to the very small gas engines. It looks like GGL is the answer. The only negative is the need to do the mixing. GGL should even cut fuel costs on large glow engines, such as my ST3000. You just need to have the recommended percentage of oil. Bronze rod bearing are the problem. I thing GGL will allow the use of a Walbro carb also. I need to read some more.
Dave
ORIGINAL: KidEpoxy
DaveW-
You posted your dislikes before I brought up the GGL 2:1GasGlow, how do you feel about that fuel rather than straight glow. Some of your points are still valid, but some are taken care of with the mix, & I dont want to pick at your post without letting you speak your peace on the GGL.
