RCU Forums - View Single Post - Importing Panos for G3 A Guide
Old 07-12-2006 | 12:48 PM
dadspet
Default RE: Importing Panos for G3 A Guide
Great guide and information. My Panos tend to have a problem because I can't seem to get the right and left side to match up perfect. WHen I create the Pano in PhotoShop CS the left and right sides aren't on the same horizon line so when I import them into G3 you can notice a miss match where they wrap around and connect. I've tried starting the pano at different places but the resulting pano always seems to miss match the ends ? SO far the only solution I have to make sure the joining point for the Piano is behind be so its not as noticeable and then to match the ends together in photoshop by adding /removing something to ends. Any idea on why this happens on my Panos.
Another thing I've noticed is that since our field isn't perfectly flat and slopes down or up in places > as I fly my plane out far on the field I will crash into the ground while I'm still in the air or Fly when I should be on the ground. Is this a fact of life in Photo Fields?
