RCU Forums - View Single Post - GLOW PLUG IN AN IVERTED ENGINE
Old 07-12-2006 | 01:11 PM
bruce88123
Default RE: GLOW PLUG IN AN IVERTED ENGINE
The #8 should do fine in an 8 o'clock mount. When fully inverted some people will use a plug with an idle bar or a hotter plug like an A3. The problem is that the cold fuel can settle down/spray down on the plug coil when fully inverted and cool the plug element. A higher idle speed also helps but most don't like to go this route.
