RE: GLOW PLUG IN AN IVERTED ENGINE
The "fuel deal" is where your tank is mounted in relation to your car on an inverted engine. If you mounted your engine inverted an installed the tank in its stock position, chanes are your tank is much higher than the carb line and it does not matter what plug you use, you will have problems
