RE: RC-10GT pullstart to non pullstart motor mount
That is the difference between the pull and none pull starter mounts. With a pull starter normally the bottom of the pull starter is lower then the engine case so you have to have higher mounts. None pull starter you have to have the motor lower so you can get something to start it on the flywheel.
