RE: Nitro MT2 problem
Is the receiver and radio working? With out the engine running is everything working? Do the wheels turn and the throttle servo work. You said it only goes straight so I am guessing the steering is not working. So I would say some sort of radio problem, bad receiver, bad crystal or crystal not in all the way, bad TX, not hooked up properly. I all so would recommend checking the batteries again. Check them with a volt meter as I have gotten bad brand new batteries.
