RCU Forums - View Single Post - Newly redesigned WH Extra 300S build thread
Old 07-12-2006 | 10:43 PM
  #45
rctom's Avatar
rctom
Default RE: Newly redesigned WH Extra build thread
Use the cooling holes in the bottom of the fuse just behind the gear. That way you don't need to cut the cowl and you will get plenty of airflow. The air will flow through the canister box and out the bottom.
TF
