RE: KAT70 Uncommanded rolling
Thanks for your reply. The other day I did finally figure out what was going on. I used the heavy duty single bolt through control horns on the ailerons. After a closer inspection I found the bolt hole had gotten slightly elongated causing play. I removed these control horns and installed what came with the aircraft in the first place. Lesson learned thanks again for thinking about this issue.
