it tends to buzz from time to time upon stick movement and not just when it's at its limits.
If this applies to your throttle servo as well, it should be rectified. You want to make sure the end point of your servo movement equals the end point of your throttle movement, or else your servo will drain the receiver battery faster than you want.
