SuperStunts 60 servo setup
Hello. I just bought a WM SuperStunts 60 from a guy at our field, and am now in the process of purchasing servos for this bad boy.
I've never had a plane that used more than 4 servos before, and this one takes four in the wing!
Any hints on how to set this up? I have a Futaba 6XA, and was planning on buying the following:
1 Hi-torque servos for rudder
6 standard servos (2 ail, 2 flaps, 1 throttle 1 elevator).
I am planning to put the two flap servos on a "Y" connector, and use two channels for for the two aileron servos. Is this the proper way to do it? I don't have seven channels, so I cannot use a channel for each servo. My thinking is that I could program flaparon on the ail servos, and along with the dedicated flaps, I could really get some strong flap action! Will this work? Does anybody have one of these? If so, could you suggest a proper setup?
It looks like a cool plane, and I cannot wait to see how it flys.
Regards,
-RCC
