RCU Forums - View Single Post - Jato Questions
Old 07-13-2006 | 12:00 PM
thundir3
Default RE: Jato Questions
Hey badz, I do own a Jato and it is not the toughest truck I have ever had. The main problem I see is that the car does not have enough braking power for the large motor and 2 speed, but what can you do on a 2wd. And the rear tower is weak even if the springs are adjusted correctly so just have an extra, because for me it was a PITA to find. I also heard that if you upgrade the chassis then the upper tray and servos dont break as easy.
