RE: How do you adj. retract up/down tension
AH yes, a plausable solution... but remember for every action there is an opposite and equal reaction... spring tension to help retract, will need an equal force to over come spring when extending... what did you gain? A possible better solution... change push rod locations on servo out put arm and / or bell crank to gain mechjanical advantage.. Why fix it if it ain't broke???? Heh, Heh, Heh
