RCU Forums - View Single Post - How do you adj. retract up/down tension
Old 07-13-2006 | 09:47 PM
Salty25's Avatar
Salty25
My Feedback: (9)
Default RE: How do you adj. retract up/down tension
Retract servos have a lot of torque anyway. They are designed to do one thing, swing 180 degrees. If you are using a retract servo there shouldn't be a problem with load; unless you have a bind in the linkage somewhere.
But if it bothers you there is the Robart air system you can put in.
