RCU Forums - View Single Post - Curing time for Rustoleum
Old 07-14-2006 | 01:09 AM
onepern's Avatar
onepern
Default RE: Curing time for Rustoleum
Hi
This is some info i got from Rustoleum. but Id thank with simple care like you are taking a week should be fine.
Danny
I have used the Stops Rust Protective Enamels on both Monocoat and Ultracoat with good results .Make sure the covering is cleaned well with rubbing alcohol then scuffed well with 0000 steel wool. I do not recommend using the Rust-Oleum Clears. I have used both the Monocoat and the Ultracoat clears over the Stops Rust products with good results. I have run up to 15% nitro without any problems with the coating. Make sure you allow the finish to completely cure (can take up to a month depending on the conditions) before firing the engine up. http://www.rustoleum.com/product.asp...ct_id=18&SBL=1
Safe landings
Jon B.
Product Support Group
Rust-Oleum Corporation 11 Hawthorn Parkway Vernon Hills, IL 60061 Ph (877) 385.8155 Fax (847) 816.2330 MSDS:www.rustoleum.com VirtualSolutions
