Hi there
I have a rush evo and it was a ***** to run in.
Here is my advice:
Make sure the mixture is extra rich
If the temerature is too hot then that can effect the running of the engine
have the jato up on a block for the static break-in and make sure the wheels are just moving and not restricted.... if you see the engine reving too much then shut it down with a rag over the exhaust or throttle back a bit ( if you cant throttle back then use the idle stop)
and persisting patience
Just e-mail me if you have any problems on
[email protected]
I have broken in many cars and i can help...
Luke
