RCU Forums - View Single Post - How do you adj. retract up/down tension
Old 07-14-2006 | 08:57 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: How do you adj. retract up/down tension
Measure the distance the arm travels on the retract mechanisim.
Use a blank servo wheel and drill two holes, 180 degrees from each other the exact distance that the mechanisim travels.
Your setup should be perfect.
