ORIGINAL: Italic orc
I have a problem with my MST. After a good run when I turn it off and try to restart it, it takes ages to restart. I can see the fuel being sucked towards the carb but as soon as it reaches the carb it just shoots right back towards the tank again. Why is that. Becuase it drains my rotostart's batt's and the whole day is done for. Please help.... [&o]
Hot big blocks are funky. Advance the throttle using the trim control. As much as 20-40% is necessary to fire a hot big block. The truck will not run away --- revs will build and you can trim it back.
If fuel runs away, advance thorttle trim 33%, engage the starter, give a blip while covering the stinger, quickly attach glow charger and fire it up. If it doesn't fire, keep charger attached, give it a quick priming burst while covering stinger and crank to start.
