RE: Digital servos go crazy
Danny
Thanks i will get with him this weekend and try all of his rec. He says that the PCM one does the same but cannot tell me the model of the rec. I will check it out. The servos dont just jitter at center. He says if you hold a load against them they just fail give up and then reset to center. Like there is low voltage. I will check his stuff ou and put on some li on's with a reg. so i know that it is not voltage loss going in to the rec. If you can think of any thing else i can check let me know. I will advise you as to what i find out.
Thanks for the help.
Robert
