RE: F27 STRYKER, WAY PAST THE LIMITS! PART 4...
Hi Everyone :
I have just got this Stryker, and I have Modified it with carbon rods across under the wings , carbon rods in the rear under the mount area, and then I sprayed it with adhesive, when it was dried I used colored duck tape to cover it.
I'm using a Himaxx 2815-2000kv motor with a Master Airsrcew 6x4 Prop, a Thunder Power 2100mah 15c 45amp ESC from G.P.
I did a Static Test its drawing 20amp, and it putting out 255 watts, I have no way of doing a thrust test, but it came in at 35 ozs AUW.
Would like everyones opinion, if this bird will fly at this weight, and if so what type of speed can I expect.
Thanks All
