ORIGINAL: Neddy191
So when I think my engine is fairly well tuned what am I looking for when I lift the plane and point the nose vertical? What throttle setting should I be at and how long should I hold it there?
Your looking for a bit of an increase in rpms when you point it up and to make sure the engine does not sag. This does not guaruntee a flawless flight because if the low end is not properly set. Bringing the high and low together can be a pain but if you learn it right, It's a no brainer.
