RE: tail motor problem...
What method did you use for the brushless converion? I soldered a new connector to the throttle channel to use for the brushless ESC. The pins of the throttle channel from the receiver still need to go into the gyro board otherwise it won't get a throttle signal to arm the 4-in-1. It also needs that signal to mix the tail rotor to stick travel.
Chris
