RE: Gp Giles 202 1/4 Scale, Upthrust Problem!!!!
Guys
I aquired a 1/4 giles and have read this forum post about 20 times and am a little confused. I am using the floor of the canopy for the datum line and have the plane set level with this point. The elevator is showing -1/2 deg and the wing is at -1/2deg as well. The engine is at -5 degree ( need to change this for sure!) I have to check the right thrust. I am trying to figure out how to set the main wing as the elevator is glued and I really dont want to cut and reglue it. I have flown it and it was a hand full I did not even get 6 min in the air with it seemed like it was a bear to trim out. Any help would be appreciated.
YS 120
16x8 APC
Hitec 645MG servos
remote glow
Weight 11.8lbs
