RE: Setting up flaperons...
You have the dial set up with the middle as the center point. That's handy if you want the ailerons to act as either flaperons or speed brakes. If you want flaperons only then have the center point set up at whichever end of the dial you want to use as the starting point for the flaperons.
Dave
