RCU Forums - View Single Post - another v-spec problem
Old 07-16-2006 | 01:13 AM
sh0wtime's Avatar
sh0wtime
Default RE: another v-spec problem
i had a 421B that used to flame out during fuel stops & going hotter on the plug fixed that too
the V-spec always seems to run best on the OS P3 which is a very hot plug!
i'd still try a fresh plug just to be sure
it sounds like a tuning/plug issue to me
does the engine still have compression when its hot? if its been cooked it will cut out when it gets hot [:'(]
the only other plugs i've used have been Sirio which have the same taper angle & thread length, i'd have to check the exact number though
