RCU Forums - View Single Post - Stop using CA glue for your tires
Old 07-16-2006 | 07:38 AM
Mike SVOR
Default RE: Stop using CA glue for your tires
no matter how you prep your tires/rims, when you hit a rock hard enough, it will cause the plastic rim to flex slightly. CA glue doesn't flex too well on plastic.
Either way, I'm done with CA glues from now on.
I'm just throwing this tip out there in case anyone wants to know about it. If you're a true believer of CA glue, fine, I don't care.
I am telling you this though, Marine 5200 is a MUCH better bond between rubber and plastic than CA glue.
Use it if ya want.
I know what I'll be using.
[sm=tired.gif]
