RCU Forums - View Single Post - What Engine for DF.?
Old 01-04-2003 | 11:37 PM
Shaun Evans's Avatar
Shaun Evans
Default What Engine for DF.?
EASYTIGER is absolutely right. Even if it's true that some have had luck getting the .91 small head engine to work in a Byrojet fan, it's not supposed to. I'd bet that the small-head engines running in Byrojet setups have a lot of visible signs of overheating, too. Use the large-head for Byrojet applications. There is a good and simple reason for it--the small head doesn't have enough cooling-fin area to dissipate that much heat. The cooling air that the vacuum creates is a fraction of what it is in a tractor-fan setup. How do I know? Burned up an engine back in '93 because I didn't want to buy the large head, even though three different people told me to. Good luck!
