RCU Forums - View Single Post - What Engine for DF.?
Old 01-05-2003 | 04:13 AM
  #37
viper21
My Feedback: (9)
Default Fuel
Well, I am a ways off from really having to worry about fuel as I am still building my Fury. I just finished sheeting the wing panels and the center section. I am planning to try a pair of those new Hitec thin wing servos for the ailerons on my Fury, I am going to install one in each panel and then one HS 85bb on each flap. So I should have plenty of power and speed. And I am using one HS 85bb on each speed brake in the fuselage between the thrust liner and the fuselage. I will run a metal geared 85 on the nosewheel steering and the rest of the servos will be full size high performance servos except for the Needle valve and the throttle. For those of you that like Fury's here is my color scheme for my plane.
Thanks Joe
