RCU Forums - View Single Post - Fueling problems, engine problems, please help.
Old 07-16-2006 | 09:21 AM
BillS
Default RE: Fueling problems, engine problems, please help.
ORIGINAL: jcfrk2002
Hello,
My friend and I have recently purchased a p-40 online through this website. We received it in great condition and were told it had flown twice. When we fueled it up it began to leak fuel by means of the throttle control on the engine, I believe this is called the carburetor. Then we were told on a 3 tube fueling system you need to have it shut, well we shut it and it began to fuel just fine. At times though it still leaks even when the carburetor is shut, what may be the problem?
When we went to defuel the airplane the fuel didn't come out as easily as it went in, in fact it came out in tiny bubbles that took a very long time to totally get it out of the tank. I had the airplane at one time running for 10 min straight with throttle up and down throughout test run and it ran great. With the same settings on the needle valve I went out to the field to fly and the engine wouldn't start. I made a few attempts tampering with the needle valve to see if that was the problem and had no luck. Its a 4 stroke engine and I am wondering what I may be doing wrong? I have never worked with a 3 tube gas system. Is there something that I need to be doing differently with the needle valve? Anything I am missing? I would greatly appreciate some help on this.
Brandon
You are starting from ground zero and should get someone knowledgeable to help. Most at the local flight field will be helpful. Attempting to learn from the ground up by experimentation will be time consuming and expensive.
Bill
