RCU Forums - View Single Post - F-4 Lights
Thread: F-4 Lights
Old 01-01-2003 | 01:25 AM
DavidR
Default F-4 Lights
I don't think there is a strobe on the bottom of the F-4. I did just pull out some pictures of the "E" model that I modeled, and the lights on the bottom are as follows. Landing lights, 1 mounted in the nose gear door, one attached to the nose strut. One on each side of the airplane directly under the intakes approximatey 4-5 feet back from the front of the inlet. There is one more light on the starboard side toward the leading edge of the vertical stab about 1/2 way down the side of the fuselage. (Top to bottom) There is one at the top of the vertical stab at the trailing edge. The colored lights are at the wingtips, how they are arranged at the wingtips is dependant upon which model, and what modification the wingtip follows. I have quite a bit of documentation on the F-4 if you could give me the model (B,C,D,E...etc...) I can look at some more pics for you.
David Reid
