RCU Forums - View Single Post - ok lets try this again
Old 01-01-2003 | 01:41 AM
Al Sabatino
Default ok lets try this again
As I have been following a lot of threads concerning charge and discharge rates, I still have not found anything on the accuracy of cycling with a charge rate other than c/10. From what I understand, a peak charger like the triton cannot find peak at c/10 so if you were to cycle with it,you would need a rate high enough to peak but low enough for accuracy. So can I rely on a peaked cycle, or do I need to charge on a different charger then discharge on the triton. On some trial tries it seems to work fine on c/2. I am looking for #s as close to the manufacture spec as possible. It would be great to hear from someone who knows more about this than me. Thanx and happy new year.
