RCU Forums - View Single Post - ok lets try this again
Old 01-01-2003 | 06:00 PM
onewasp
Default ok lets try this again
Al
Thinking a little further on your question, if the difference between "full charge" on a peak detection charger (assuming a reasonable design and Mfg. execution of the design) and C/10 charging is worrying you then you are flying way too close to the limit.
Trying to put it into perspective, the last 20 to 25% of throttle opening on your engine gives an almost indiscernible difference.in RPM.
That is where we are in your battery/charging/capacity discussion from a practical standpoint.
