RCU Forums - View Single Post - ok lets try this again
Old 01-01-2003 | 06:25 PM
Al Sabatino
Default ok lets try this again
What I am trying to find out is if my numbers when cycling are measured close enough to the same way the manufacture measured when they come up with say 3000 mah's This way if I go to cycle a pack that has not been used for some time,I can compare my #s to that of the rated capacity of the pack. In the past I would charge with C/10 and then discharge with an ace abacus. Now that have a triton I would like convenence of one step cycling at a quicker overall time but somewhat question its results relative to manufature spec (rated capacity). 97.5% of full charge does sound close enough for a reasonable comparison. That was partly what I was asking. Onewasp, what rate of charge did you use to get that close to a full charge? I read somewhere around here it was a little closer to 95% (wasn't really sure of that # either).
