ok lets try this again
550 ma was used on peak detection. 500 ma was my discharge rate.
I ran my tests multiple times, to get a handle on the number.
Then, I could repeat the results at will.
I wouldn't be concerned with a 5% differential if I were you. The actual flight loads, time and temperature will cause a wider variance than that and we generally don't even consider them at the field.
