RCU Forums - View Single Post - HOW DO YOU DRIFT WITH JUST 2WDRIVE?????
Old 07-17-2006 | 07:25 PM
  #65
grunho's Avatar
grunho
Default RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE?????
my opinion is this subject is. 1:1 scale 4wd can drift (hardly because when entering a curve you slide with the rear and control with the front but if the front starts pulling it will stop the drift, unless the car balances the amount of traction between the front and the rear) so in 1:10 it would be the same but the engine its in the middle instead of being in the front so it changes the whole theory, i have an awd car but i´ve taken the front shaft so now its a rwd. how i do to drift ? simple imagine a left turn i turn the wheels a bit to the right then full to the left apply a little of brake (disc brake) then i control the drift turning more or less to the right. So i dont know really how but i drift in a 1:10 car has i drift in a 1:1 (the 1:10 has an 911 Turbo shell) and the 1:1 that i drift is an nissan 350z and its rwd but its just my opinion
