RCU Forums - View Single Post - wingtip covering question
Old 07-17-2006 | 09:00 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: wingtip covering question
ty, IF you've seen the covering videos I did recently, you've seen the technique for doing a rounded tip. For a flat tip the technique is very similar.
Do the Tip first - Cover the flat part with an iron, then use a heat gun to stretch the covering around the top and bottom.
Trim it off at about 1/4" past the tip
Now cover the bottom, and then the top, and trim the covering flush with the tips
